high idle after warm up.
my car idles great when it cold, but after it warms up to around 200 degree's it jumps the idle up to around 2,500 rpm. If you unplug the IAC and adjust the stop screw in the thottle body it fixes the problem.
So does this indicate that the IAC is bad?
Somebody reccomended I check the timing. I know I bumped it up a little, I think I set it at 14 degrees but cant remember, should I set it back down to 10 degree's?
Matt's 95 Stang
10-05-2015 07:16 AM
mungodrums
Suspension
09-24-2015 10:12 PM
