Smog pump delete
RE: Smog pump delete
770k6 is the correct size belt http://www.fordmuscle.com/archives/2...ps/index.shtml
ORIGINAL: rmodel65
Thanks,
Jeff
should pass no problem. I think you mean just disconnect the air injection from the back of the heads only, right? according to the EEC-IV book, air only injects to the back of the heads during cold startup to mix better with the unburnt fuel from the rich mixture so it can burn completely in the cats. after theengine is warm, the air injects only into the cats. I passed a few years ago in NJ with 302 with 1970 351W (non emissions legal heads w/ no air injection) with high flow cats with the air injection injecting only into the cats. also had a non emission legal lunati custom grind cam. passed no prob and the readings were actually cleaner than the stock cam/heads/cats. From what I've read, you NEED the air pump if you have cats otherwise the cats will run too hot and be destroyed. I failed at first thisyear because the air wasn't injecting into the cats properly. after I changed one of the solenoids and fixed it so it injects, I passed with no problem.
(sorry posted to the wrong board)..........it is possible though to remove the pump and run a shorter belt. i actually keep the shorter belt in my car because i've had 2 smog pumps seize up and can just throw the shorter belt on now to get home. (don't know the size off hand though)
