Fitting issues...I'm stumped.
RE: need help
one quick question, do you have the motor mounts on the correct sides? I know it sounds dumb but that 351 should fit in. Everyone and their brother are doing 4 cyl to v8 swaps in notches and if it involved a k member for every swap tube k members would be dirt cheap. I put a 5.0 in my turbo tbird k member and it fit fine with no problems at all!
RE: need help
you may have them on the wrong sides, the mounts are side specific, it may help to put the mounts loose in the k-member and then when u lower the motor, you can make it line up to the block, and start the bolts before setting it in.
jwog666
12-27-2021 08:09 PM
BeatnikFink
10-01-2015 08:00 PM
