Trans Fluid?
Trans Fluid?
This is the transmission i Have in my car and im changing the fluid in it. WHat would be the best oil to put in it? I dont know if it needs a special oil other than stock bc of the Gforce stuff? I know G force uses straight cut gears.
TMS Hp series T5 Ford Transmission
HpseriesT594-95
This is our HP series T5 transmission rated at 350 Hp / 350 lbs trq . It features 3.35 ratio with .68 overdrive , race cut syncros , G force cluster gear retainer plate , steel bearing retainer and high speed balanced mainshaft .
HpseriesT594-95
RE: Trans Fluid?
ORIGINAL: 94TealGT
what is the benefit of GM synchromesh over what Ford puts in their T5?
Matt's 95 Stang
10-05-2015 07:16 AM
09-25-2015 06:42 PM
