torque spec on pinion nut
RE: torque spec on pinion nut
ORIGINAL: mjr46
there is no torque spec ..you have to tighten it down until the crush collar crushes and applies the proper amount of preload which you use a turning torque. wrench that measures rotational drag the spec for this is with a new bearing 16-29 inch lbs using a torque meter that measures turning torque
um, that would be called an inch pound torque wrench.
why are you replacing the crush sleeve? what's going on with the rear end?
ORIGINAL: dillon1340
ORIGINAL: mjr46
i used a screwdriver in the hole in the flange to hold it, my impact wasnt even strong enough, i had to use handle of the jack on a breaker bar using my leg. But you need to get the inch lbs measurement before you put the crush sleeve on.
ORIGINAL: blk40th
cant i use my hand to hold it? ill set the pinion first then set the backlash right.carrier shims go on the ring gear side or the pass. side. i think i just need to pull it apart then ill be able to actually see what going on with it.
ok well ive decided not to even try the new crush collar. im just getting that kit from brenspeed. im goona get some 3:73's and all the bearings shims, etc. o well now ill be $600 into this rear. but itll be solid after. i got someone to do it for $150. thank you for your help guys
KingRando
10-02-2015 08:06 AM
