dashboard swap how hard?
RE: dashboard swap how hard?
is it coming with a new gauge cluster?, if not get a torx bit set too. You'll need that. I just pulled mine out and replaced some old wiring and hoses and stuff and reinstalled it. its about 5 hours worth of solid work. can be done in a day but most likely in a weekend
Its not too bad... you don't need the torx bits either as they have a hex head on them anyways and some years just had philips screws holding the guage cluster.
It does help to have a friend give you a hand.
on thing that will make the install easier is be organized, put all your screws and bolts from one peice in a bag n lable it n do the same for each part. it may take a few extra minutes during the tare down but you will thank your self during the reinstall.
ORIGINAL: Dave5point0
If you do the dash then buy the doors, headliner, pilars, carpet and seats too, just the dash buy itself looks weird if you have babyblue or pornored everything else
