losing voltage??
losing voltage??
my voltage drops when I turn my headlights on and If I also turn my heat on high the voltage drops down so low it almost stalls the car when I come to a stop. If anyone has any input it would be greatly appreciated!!
RE: losing voltage??
That's normal. Welcome to the world of the undercharged foxbody. I recommend doing the 3g alt conversion to take care of that.
ORIGINAL: 1mean5.0
i was thinking of getting ud pullies anyway so maybe I will try that. Then later on down the road I may also do the 3g!! Thanks guys
ORIGINAL: PRO50SC
i upgraded to a 200 amp 1 wire alternator, moved the battery back into the rear of my hatch, and installed 2 600 cold cranking amp high output batteries in parralel. That more than took care of my charging issue, have not had any problems since.
