Need Help ASAP!!!
Need Help ASAP!!!
Hey all i am going to be ordering a new mass air meter tonight and need to know if the Pro-M mass air meter is legal or not... Thanks in advance....
Ohh if you can tell me were the carb E.O number is on the net or where it says that it is legal in California... Thanks....
RE: Need Help ASAP!!!
No i just bought a 1988 mustang GT... But are you sure that its legal because i have to pass smog and the stocker MAF is bad.. The reason i believe that its bad is because my car throughs a check engine light when given throttle and at high rpms, such as 5300rpms, i get black smoke...
ORIGINAL: bobby
its should be perfectly legal. i thoguth that stang in ur sig is ur only car?
you might use a code scanner to be certain what is wrong before you go buying a $200-$300 MAF, my pro M doesnt have an E.O. on the unit itself. I got it used so I never seen the origonal packaging
Well i ordered the Pro-M 75mm MAF so its a done deal, but thanks for the opinions... What else do you think could cause the problem??? I think its the MAF or 02 sensors, thats the only thing i could come up with...
ORIGINAL: Dan89lx
Hey thanks for the thought though... I wish i would have known but i need the MAF here as soon as possible so it was a hasty decision... I have to get the thing smoged ASAP so that i can get it registered without problems... You know what i mean???
Thanks though....
Just for the sake of asking...How much would you sell them to me for i might think about it if the offer still stand for later on down the road....
Thanks though....
ORIGINAL: angcobra
Wished I had seen this earlier, what injectors you running? I have a PRO-M 75 MM Bullet and 24# injectors I just took off I could sell.
