Pinging sound at high rpm
RE: Pinging sound at high rpm
mine did that when i first got it... so i used sea foam and premium gas.
if you don't want to use premium gas, try sea foam then if it still pings check your timing and adjust accordingly.
also check your spark plugs to see if the problem is predetonation. if you advanced your timing you could possibly try a colder spark plug. just make sure it isn't fouling.
good luck.
good luck.
panic
09-10-2015 05:56 PM
