questions about tfs intake manifoldsw
what is the difference between the tfs streetburner intake manifolds, and the tfs track heat intake manifolds. And if the throttle body bore diamater is 75mm does that mean i should get a 75mm throttle body? And what about the basic operating rpm range, if i were to purchase one what should i look for there, what improvments in power would i see after intalling this?
RE: questions about tfs intake manifoldsw
It depends on your use for the car. Does it have stock heads? The TB opening should be 70 or 75mm in dia.
Give us a little more info on the use of the car, and maybe we will be able to help you out a little better.
Track heat has shorter runners to give you a little bit more high end hp while scarificing some low end torque. Dont expect any significant gains, headsmake all the difference on the 5.0
Luke9222
10-22-2015 11:55 PM
