pedestal mount rockers????
RE: pedestal mount rockers????
there is no adjustment. if you DO need them adjusted (due to a valve job or new cam) you need to either get different length pushrods or depending on which way you need to go you may be able to just use shims under the rockers
After finding the correct pushrod length you tighten them down to torque spec. After you reach zero lash it should reach torque spec within another 3/4 turn I think it is.
ORIGINAL: RedHatch92gt
its a e cam with 1.6 roller rockers do i need new push rods??
no i had a big problem because i had 1.7 rockers and e cam...so i sold 1.7 and bought 1.6 im gunna have to email frrp or if u know a good pair for me...if u have summit magizine tell witch set so i can order...351w heads ported with e cam.. 1.6...thats the setn up..
jwog666
12-27-2021 08:09 PM
