autometer tach wiring question...
Old 12-02-2007, 04:58 PM
DoctorD415
DoctorD415's Avatar
Default autometer tach wiring question...
I wired up my tachometer and got it working. Green to msd box. White to dash light fuse. Red to ignition fuse of some sort. and ground to ground.
Tachometer works until i put the dash lights on, then the tach stops working and the the tach doesnt light up. Tach is like new and i doubt the light in the tach is bad, but i tried just finding any hot fuse and getting power to light it up and i couldn't. If i shut the dash lights off, the tach will go back to working. Any idea whats going on?
DoctorD415 is offline
Old 12-02-2007, 05:04 PM
84conversion50
84conversion50's Avatar
Default RE: autometer tach wiring question...
not sure what you did. usually one wire on the negative side of the coil then power and ground.
84conversion50 is offline
Old 12-02-2007, 05:37 PM
DoctorD415
DoctorD415's Avatar
idk i followed the directions i got with the tach.
There are4 wires,
1)Ignition Switched power wire(red)
2) Ground (black)
3) Switched dash lighting(white)
4) and Tach Terminal to msd and or coil (green)
Old 12-02-2007, 05:56 PM
84conversion50
ok
1)Ignition Switched power wire(red) --- splice this with something such as a cigarette lighter or something else thats only on when the car is.
2) Ground (black) -- duh
3) Switched dash lighting(white) -- headlight switch.
4) and Tach Terminal to msd and or coil (green) -- negative on coil.
Old 12-02-2007, 05:59 PM
DoctorD415
DoctorD415's Avatar
Should i put the white wire to teh fuse box?
Old 12-02-2007, 06:07 PM
84conversion50
i have had nothing but problems when i put it with the dash lights but if i do it to the headlights its fine. and i put mine in the box.
Old 12-02-2007, 06:15 PM
DoctorD415
DoctorD415's Avatar
alright ill try doing that and then putting my switched power to the radio.
Old 12-02-2007, 06:26 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Do the other dash lights still work when the tach goes out? Sounds like the white wire is connected to the wrong wire.
PRO50SC is offline
Old 12-02-2007, 06:31 PM
8banger
8banger's Avatar
ORIGINAL: PRO50SC
That orhe doenst have a very good ground ....
8banger is offline
Old 12-02-2007, 08:09 PM
fourfivefour
fourfivefour's Avatar
Only connect the green wire to the MSD box!
If you connect itto the coil it will damage the tach.
It sounds like you may have a ground problem. With the lights off it may be back feeding through that circuit to get ground. Check your ground is good.
Disconnect the light/white wire and start the car and connect a test light between the white wire and a known good ground. If the light lights up or the tach stops workingyou have a bad ground
If it's ok the tach is bad.
fourfivefour is offline
Quick Reply: autometer tach wiring question...
