Problem with idle
RE: Problem with idle
try cleaning you IAC, or replacing it, its cheap. other things you can do that wouldnt hurt is it clean you maf sensor, check for vacum leaks. it could also be your coolant temp sesnor. mine went bad and made my idle surge bad, i noticed you also hae the b303 cam, i have it in mine to even then it still jumps a little bit.
ORIGINAL: 89chatofive0
Car idle jumps up and down between 600 and 1500 rpm then stalls. i took all the smog equip off what coculd be the problem?
Okay I put a new Idle bypass valve and now i got the idle right where i want at about 900-950, but this morning i let the car warm up, went into the house, came back outside and the car was idling at 2500 rpm and would not go back down, i turned it off and started it again and it idle just fine what is the deal?
