starting issues
starting issues
hey guys my 89 gt has a starting issue. after it gets warm( the car) when i shut it off and i start it up it has a weak crank, like the batterys going dead. i tested the altenator and the battery and they are good. my dad thinks its the starter, but if i put a jumper pack on itwhen its warm and crank it it starts right up. i need some input
RE: starting issues
ORIGINAL: kdsmppt
re check ur alt also ur system might be grounding out test the batt with it in the car off that at start than runing.
RE: starting issues
i did a load test with it off with my dads battery tester and then i checked it while the car was running and the charging system was good,i do remember one night leaving my girlfriends i started it and the starter just kept going after the car started and i shut it off and the starter kept going still even with key off and out of the ignition. i know i bought a new starter relay from autozone and its a wells and i know wells sucks[:@]
