mark fsn help!!!!!
mark fsn help!!!!!
the fan does not fit in my car i mean i made fit up triming it all the way down it still wont fit likehow everone elses does. i have it virticel on the drivers side. everything is stock still like the rad. any ideals? the water pump pullie contacts the fan motor.
RE: mark fsn help!!!!!
ORIGINAL: kdsmppt
trust me its trimmed all the way down to the point that i had to use spacers to stop the fan from contacting the rad and rubbing. alright ill try to go with the taures one how good does it work? the mark fan pulls like no other.
It will fit, trim away.
Also the fan will sit JUST under the water pump pulley
I probably only have 1/8" clearance from top of fan housing
to water pump pulley, but it DOES fit when trimmed down
and mine is on an extra thick 3 core Fluidyne radiator
So rbarn, you got the Mark fan to fit?? I have the 3 core fliudyne also, I was get one off ebay and me and the seller PM'd each other like 4 times. By the specs he gave, the fan would hit my w/p pulley by smigges, he said he couldnt trim it anymore, so I am still looking for a good fan. How'de ya do it? Our cars look pretty close by your posts.
The fan has to sit JUST under the water pump pulley
If they were lined up, then yes they would hit.
My fan sits about 1/8" below my water pump pulley
with as much trimmed as you can.
It fits perfect on mine.
I even have "Vert mounts" which lower the engine another 1/2"
below normal "Hatch mounts".
That's another thing to check. Are your mounts bad? and causing
engine to sag down or lean ???
There solid motor mounts, so I would say no. I didn't check clearance if I moved the fan down below the w/p pulley but i didn't want to buy something and find it didn't work, guess I couldve re ebayed it, but it sold. Looking for something other than my black magic, doesnt seem to cover alot of rad space.
08-12-2015 05:39 PM
