tranny question from 2.3 liter to 5.0 liter
Alright everyone I had a 2.3 liter 4 cycle motor/tranny in my mustang now i'm swapping it so I have a 5.0 v8.
I read somewheres that if I just change the bellhousing (one off a v8 t-5 tranny) and put it on the tranny from the 2.3 liter it will work fine handling the 5.0 v8 anyone know if this is true?
RE: tranny question from 2.3 liter to 5.0 liter
I am pretty sure the bellhousing is different between the 2.3 and 5.0but the transmission will bolt up as long as you get a different pilot bearing. If it is a stock 5.0 the transmission will be ok but it is not rated for even a stock 5.0. You can get V8 gears and put in your transmission and upgrade it to V8 standards. You will need 1st, 2nd, 3rd, speed gears, main drive and cluster. The output shaft, sliders, etc. are all the same.
ORIGINAL: 92GreyGT
mjr 46 is right, the gear ratios are different (much closer) and the toque capacity is only 240 lb-ft as opposed to 300+ lb-ft.
http://www.allfordmustangs.com/Detailed/349.shtml
