I fixed a vacume line and now it misses worse?
I noticed underneathe the upper intake manifold there is a vaccume line coming out from the intake manifold right behind the distributer, well I noticed my was leaking very bad and I thought thats what was making my car miss from idle to 1500 or so whenever I started the car, and it goes away after like 3 minutes of driving, Well after I replaced the vaccume line it misses worse and misses and doesnt go away, so its missing all the time, what could have caused this?
RE: I fixed a vacume line and now it misses worse?
Where does the other end of the vacuum line lead to? It might be a bad part connected with the ECU.
If so, unplug it at the part, plug the hose, then see what happens.
Okay, I went out and looked at my Lincoln, the hose coming from the front underneath the intake leads to the right front corner of the engine compartment to the charcoal canister. I had a leak there before too, and was getting a code from the computer for the charcoal canister solenoid, so I just plugged the hose and it runs fine?
TfcCDR
09-14-2015 12:08 PM
09-08-2015 11:50 AM
