baer brakes
baer brakes
i just bought this brake kit http://cgi.ebay.com/ebaymotors/ws/eB...m=260181660241 what master cylinder and brake line components do i need to put this kit on my 89 lx?
Thanks
Thanks
RE: baer brakes
oh ya, youll also need a 5 lug conversion. and it says theres no brackets, so you need brackets too.
it is better to research before buying, but it may end up costing a bundle to get it on your car.
RE: baer brakes
www.sn95brakes.com
This will tell you everything you need to know. Just substitute the baer brakes for stock sn95 brakes
RE: baer brakes
Its really too bad you spent all that money. You realy should ask us before making large purchases..
you can buy those calipers for $45 a piece at Advance Autoparts, the drilled/slotted rotor set for $275, brake lines are $22 each
the only thing you would have to get are the caliper brackets... and im pretty sure LRS sells them.
basically... you got boned
RE: baer brakes
ORIGINAL: 83gtragtop
You need:
-SN-95 spindals
-1993 Cobra master cylinder
-proportioning valve
-5 lug axles
-the correctparking brake cable
and maybe some more to....
You need:
-SN-95 spindals
-5 lug axles
