manual brakes
manual brakes
im concidering swapping to manual brakes but dont know much about it? has anyone done this wish factory brakes? maximum motorsports doesnt recomend it with factory brakes. im just trying to spread some light on this so i know if i want to do it or not. what has anyone done? how did you do it and what kind of parts did you use?
RE: manual brakes
dont go manual brakes just swap out lighter brakes
chcek out aerospace brakes, willwood brakes, or strange brakes
from what i have read strange is the better option as they are lighter than the aerospace brakes, but more budget friendly than the willwood set up
RE: manual brakes
Just a tad bit cleaner in engine bay, no vacuum hose. And come in handy when running a big cam. I have man brakes and only pull 8 inches of vacuum. The pedal is stiff but if you have a good system there is no problem stopping, even though i would not want man brakes with a daily driver.
RE: manual brakes
i only have the e cam with 1.7 rr and ive found out the redrilling the brake pedal can change the ratio and make it easier but not to sure if i want to do it on a street car or not.
RE: manual brakes
ORIGINAL: 86stanglx
