Where to bolt up to on motor w/ hoist.
RE: Where to bolt up to on motor w/ hoist.
ORIGINAL: dimebag
your over stressing...
throw a bolt in the front right and back left in the heads where header bolts go... and pick it up... ive done it numerous times w. iron heads(not aluminum tho, but id do it w. them too) or use the accesory holes in the front/back of the heads w. a bolt
ORIGINAL: jbguillo
no way i could use the lower intake manifold....Just torquing bolts in there past 15 ft lbs will cause the threads to pull out. im kinda stuck guys.
trick flow heads, they're aluminum...I dont want to put strain on those threads, because i have pulled them out before just wrenching on them with going over 15 ft lbs of torque.
ok, leave the heads on, use a seatbelt, like r.barn said, hes right, its easy, it works.... my explorer motor was picked up like that
i should have taken a pic earlier, i had my motor in the air again(the header bolt way)...and it was fine... if really need be, i can take pics tomorrow, im doin it all over again, lol pulling the one outa my car
Use the back of one head and the front of the other head. Its the bolt that holds the Altenator Bracket and on the the back of the other head its the same size bolt. I did it with aluminum heads too. Its perfectly safe.
picking it up by the header bolts? sure, ill do that...
as for the short block... its getting pulled out by head bolts, because its in the car, and its just the shortblock... ill thread in 2 head bolts, and lift it that way...
00limited7
05-16-2007 02:52 PM
QWKYNUF
08-09-2006 10:49 PM
