smog pump hose removal
i have a 95 gt i have removed the smog pump and added the delete kit i want to remove the hose that runs back along the block and the turns in to the hard line it looks like bolts on does it? if i remove it will i need a plate or something to cover it.
thanks dustin[/align]
RE: smog pump hose removal
youll have to make a plate for the back of each head, i used 1/8" steel cut to about 1.5"x1.5" then drilled a hole for the bolt. after that just block off the small tube that comes from the cats so your exhaust doesnt leak
your not supposed to delete it when you have cats because "they" say the cats will clog, but when i took my smog system out i found that the vacuum sollenoids were crackedandlooked like they had been for a while,meaning the system hadnt been working for thousands of milesyet my cats are in perfect shape. Anyway my point isi wouldntbother removing the cats
TfcCDR
09-14-2015 12:08 PM
