cracked timing chain cover?
anybody ever have a cracked timing chain cover? reason being that im getting having oil puddle up in the valley on both sides of the cover. i checked and replaced dist o-ring seal and im stilling getting the oil up there. what is the best replacement for this, and gasker?
RE: cracked timing chain cover?
you need to clean all the oil off and watch and wait for it to leak and trace it to the source....however my guess is it's the lower intake gasket that's leaking at the corners of the front end seals on the lower intake
just did that, looks like its coming from the gasket, thereis no oil flowing down from the intake. it has a paper style gasket on it. i thought it was the dist o-ring but i just changed that. anyone think it could be the gasket?
thats sounds like fun. im 95% sure its coming through the gasket. cleaned it up again and let it run and slowly the valley filled with oil. nothing coming down,just coming up. fu**** pissed. now i got to ripe the **** back apart and fix it. man
Hey man listen up if it is the gasket no problem but your still gonna have to replace all the gaskets for the timing chain cover. Get the gasket set from Autozone, Oreilly or wherever. You might want to get a new timing chain and spockets while your at it. That said you could change the cam but if your still using the stock heads just wait .
the problem is in the oring for the dist i just replaced. im going to put another one in. thought it might be the gasket from the timing cover but that doesnt leak at all, i cleaned it big time and the oil is cover over the dist seat. so i know that is it for sure.
the car has e303 cam,edlebrock timing chain and gears, trickflow upper,lower,heads. so i dont have to worry about that.
thanks for the info though.
Steve@CJPP
CJ Pony Parts
08-19-2015 08:52 PM
