Oil Choices in High Mileage Motor
RE: Oil Choices in High Mileage Motor
Wow, thanks for all the advise. Confirms I should go back to my Valvoline next change, may just go ahead and change it this weekend. Like watching money pour down the drain so to speak, but ya, I think a regular (Valvoline Racing or Castrol) will be better until I can tear it apart. To Texas5.0, I live in Tomball but drive to Clear Lake NASA JSC every day until I get transfered to another job (construction superintendant), but it could be awhile. Either way it goes, I generally do some traveling, Houston's a big area to travel. Again, thanks for all the posts
ORIGINAL: awormofearth
the previous owner of my mustang always put castrol 20 50 in the car. after i bought it, he didn't tell me this, so i put 10w40 in it. 1000 miles later, the check oil light was on and my car was running like ****. so i found out what oil he was using, put some nonsynth castrol 20 50 in there with a quart of lucas, and it's been running great. it'll take some serious convincing to get me to switch to anything else
Got a good idea my valve seals are bad, whitish smoke out the pipes. My pressure is good, start up around 50- 60psi, 2200 RPM round 40, idle and operating temp 32 PSI. Just slingin lotsa oil lately with the Royal Purple 5W-30. I added the LUCAS, and helped a bit.
I've been using Motorcraft syn. blend 10w30. I usually burn/leak about 1 qt per month. I am changing my oil tommorow, I was going with syn. but I'm not now. I would go syn. on arebuilt engine or new car though.
Great... reading this has me worried now. I have 70k on the clock and was going to switch to Mobil One synthetic. Just put a rear main in, so hopefully no flow there...Should I bother to switch???
i run 10-40 year round im in south ga no real colds days. and i dont drive it in the cold thank to my leaking again heater core the new one lasted on winter part of the summer and now pours[:@]
ORIGINAL: uenvyboykin
I would not recomend anyone using Lucus, or any other oil additive, I did some research on oil additives. Ya it works great at advanced auto parts when your turning that little wheel, but the fact of the matter is that most oils(any good brand oil) already has there own added, and when you add others it messes up the compound of the oil, and actually can harm your engine...
Old engines begin to wear out at every rotating or moving part. Wear means more space between parts. Also as gaskets age they begin to deteriorate, and leaks begin. Synthetic oil is more slippery than dino oil so it leaks out more. I use M1 5-30 in all my 5 vehicles, including two over 125K miles; one a 94 v6 that is my daily driver of 60 miles and I hammer it routinely, the other a 96 Blazer with 158K miles that purrs. Whatever you choose, just realize that it'll leak so just keep up with it til the rebuild. No additive will be good for long.
One additive I can recommend, altho pricey, is AutoRx. A long term cleaner of any part that oil comes in contact with. Auto-rx.com I think. It takes a while and some cash but it actually restored lost power to my DD I think because it cleaned the stuck rings which increased compression. It also cleaned the hydraulic lash adjusters on that car (lifters) which were clogged and decompressed, creating space and therefore allowed noise. Check it out.
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
