RPM'S try to drop then car dies
hey yall i guessI am an idiot now cuzI have no idea what my car is doing. wellmy stang has a mind of its own. I have been having problems with the car wanting to start. i have changed a few parts that i thought was wrong: Fuel pump and filter, fuel pressure regulator, plugs and wires, mass air flow sensor, IAC sensor, and ignition coil. Ive talked to a few buddies down here in Jacksonville, Fl. and some of them were saying my igition control sensor might be going out so today I changed that. After i changed it i started the car and it ran like a champ so I thought all was good.Well upon driving it around the block the car tried to stall out on me. I mean like the car was driving and then the RPM's would drop but the car kept driving. It done it like 10-15 times in the 15 mins of me driving it around the block. I dont think it is bad gas because when i got to the house i turned the car off and now it wont start again. I AM TRULY FED UP WITH THE STANG but I have some loyaty to the stang and I want to get it running and keep it. If anyone has had this problem PLEASE HELP. The car isa '91 LX convertible. Thanks
RE: RPM'S try to drop then car dies
have you changed your tfi module, it sits on your distributor. Sounds like that could the be the issue to me.
edit: does it happen all the time, only when the cars cold, only when the cars hot?
and take a look at your TPS (throttle positioning sensor) from what ive seen fords seem to have a problem with theirs. ive changed them on f x50s, escort, mustang, and even a sable
ShaneB26154
35
03-04-2021 04:05 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
