High Idle
High Idle
Hi Guys,
I did a H/C/I swap on my car. Before things would be fine and the car runs smooth. Now it's really starting to run weird. In the beginning when I drive her, things are cool. But as time progress the same time I'm driving and pull up to a light, my RPM goes up to 2500 and wont let up. Even then while I'm driving the RPM stays up. I still have a stock computer, would that be the problem?
Thanks for any input you can give
RE: High Idle
i think one time i MAY have seen it done with some kind of intake(efi) cleaner, you can listen for leaks and then spray the cleaner where you here the leak, if you hear the rpms jump then there is a leak, but you really just have to listen should b that much of a problem
