What is a good setting for the TPS?
RE: What is a good setting for the TPS?
I need to know how your guys' idles after setting to .98 because mine went crazy at .92 .. So I kept it at .81 for now until I get a response. Also, does the car have to be running to set the TPS? It is a little uncomfortable to be leaning over the engine with it running. please respond.
No, the car shouldn't be running but the key should be in the "on" position when you set the TPS. When I set my TPS to 98 I noticed alot more "snap" off the line then before. I hope that helps. Good luck!!
Insidian
Carolina Regional Chapter
09-08-2015 05:33 AM
