kenne bell
#51
RE: kenne bell
I'm running a stock 5.0 with a Kenne Bellat6 psi and 19 lb/hr injectors with an FMU. Runs just fine.If you keep your boost at 6-8 psi, you don't need a custom tune, larger MAF, larger fuel pump or any of that jazz.
I've been running this combo for 8 years with no issues. No blown head gaskets, no burnt pistons, no probs.
#54
RE: kenne bell
hey as said above that kb will only whine if the boost is high...u dont have a video of urs going down the road do you?...id like to hear what it sounds like at a boost level like what your running
#55
RE: kenne bell
ORIGINAL: Hicompression
#56
RE: kenne bell
Just wondering, if I take that 3600 for the kb and run a different direction and do something like the trick flow top end with exaust, maybe an underdrive pully and some lower gears, how would that compare to 8-10psi from a kb on a stock motor?
#57
RE: kenne bell
with that money if u want to stay naturally aspired..u can piece together a kit that gets more power per dollar spent than by going with trickflows kit...im not saying its a bad kit..ive ridden in a 95 with the stage 1 kit many times..my friends..and its definatly fast...but u can do better for 3600 u can almost buy an entire motor minus intake from fordstrokers and have a sweet package
#58
RE: kenne bell
Similar gains, a guy with an 11psi KB on a stock 5.0 made just over 300whp, huge torque though. That was with the 1.5 kit. Putting together a good h/c/i you should be at a similiar point.
#59
RE: kenne bell
Either way I would still need to get the bigger injectors/fuel pump/tune/whatever though right? With a lower gear, would the car still feel like it had all that lovely torque? What H/C/I combo would be better for the money, how much would it hurt to keep the stock cam?
#60
RE: kenne bell
if ur heads are off already might as well put in a better cam....the stock isnt worthless....but theres much better outta aftermarket..if u go that route give ur head details as well as intake n get a custom cam ground thats the best way to go..off the shelf cams arent bad either if u want to save some money but custom is always better..as for fuel..my buddies 95 with tfs1 kit has 24lb injectors..stock pump, and hasnt been tuned yet n it runs fine...sure theres more in it with a tune but it runs good now too
DOHC330MustanGT
09-13-2004 02:54 PM
