Hard to get into gears
all of a sudden its really hard to go through the gears i have to force it into the gears and reverse grinds . it just started doing this out of the blue and i just changed the transmission fluid with royal purple.
RE: Hard to get into gears
ORIGINAL: josh gt
it feels good i thought it could be the clutch master cylinder...
ORIGINAL: mjr46
fox body stangs are manual/cable operated..not hydraulic...unless someone spent alot of time to convert it .....you got a cable operated clutch that works off of the pressure plate tension[&:]
ORIGINAL: josh gt
so does the pedal tension and free play feel okay???? if the cable is not binding and clutch pedal feels okay then what were you doing when the problem happened..running it hard??? or driving normal??
