What does speed density mean?
RE: What does speed density mean?
Speed density FI meters the fuel according to engine speed. This system is useless if you make modifications since the FI system is basically set for the stock setup. Mass air flow systems actually measure the mass of air that the engine takes in and meters the correct amount of fuel for any given amount of air. With the MAF system you can make mods that will increase the volumetric efficiency of the engine and the MAF will cover it.
NO it means you hafto convert to mas air system
the coumpter is set to stock engin combo and can not make adjustements for mods IE the coumpter is dumb and blind
the mas air systems measure the air intake and give the fuel to suite . as soon as you want to do mods you hafto convert to mass air or get the speed dens coumpter reprogramed FOR EVRY ENGIN MOD so they hafto all be done at once and a new coumpter made or make a new coumpter after evry engin mod UNDERSTAND
CONVERT TO MAF FI SYSTEM
you need a mass air eec (a9l, a9p,a9s... etc) , mass air tube and sensor with the electronics and a good length of the wires so you can move the correct wires around on the eec harness.... and a 88 cali+ intake tube....
Here's some instruction on the conversion....it says for a Lincoln Mark VII, but it also applies to a Mustang, the only thing different is the cruise control re-wiring, the computers are the same.
http://www.lincolnsonline.com/article77.html
ORIGINAL: 87 hatch
I have an 87 gt and the air filter intake is called speed density. What does this mean and how does it compare to Mass Air Flow Sensor?
MAF systems actually measure the intlet air flow and temperature so they can respond much better to mods than a speed density system can. they also have a more sophisticated computer program which works with the MAF to allow better control of the engine functions. You can get a complete plug in MAF conversion kit form Ford Racing Performance Parts for around $600 which comes with a MAF, new ECU, and wiring which just plugs into the existing harnesses once you replace the ECU with the new one.
Speed density systems were the first systems used for computerized fuel injection but they have been replaced by MAF sytems since '89 in Stangs as the MAF sytems are just better for control and emissions purposes.
BeatnikFink
10-01-2015 08:00 PM
musnicki
09-23-2015 07:11 AM
