low oil pressure
RE: low oil pressure
Ill tell you something, since I learned the hard way, .
Whenever you have the engine apart, at least put new bearings in it to save yourself a headache.
I watched a guy put a trickflow top end on a New 306, but a little coolant from the job got in the
engine. He said it would not hurt nothing, and his car's oil was not milky.
I told him it had a shine to it, 9 months later, low oil pressure. Crank and rod bearings wiped.
ORIGINAL: aode06
i bought a $200 motor and dropped it in because i needed a car to drive to work and back. i dont have to much money at the moment and if i would have bought the bearings i wouldnt have been able to buy all the fluids. bearings are easy to do later in the car. oil pump seemed fine when i used a distributor primer.
jwog666
12-27-2021 08:09 PM
ccdguy
09-19-2015 05:20 PM
