lifters in order?
lifters in order?
Hey, this is somehwat of a post facto question, as I can't really do anything about it at this point. but how important is it that the lifters are replaced in the same places that they were originally? Cause I read you are supposed to do that AFTER I had not done so...guess there's not much I can do at this point.
RE: lifters in order?
ORIGINAL: 89GTdude
If its a solid lifter cam then it is very critical , if ithas roller liftersI wouldn't be to worried about it.
if they are rollers there is NO reason you need to replace them for any stock to mild performance build. if they are flat tappet you NEED to keep them in order. if they were flat tappet and you mixed em up, you cna use new lifters on a used cam with no problem (its using used flat tappet lifters on a new cam that wont work... just for clarification)
but with roller, anything goes
i hate your name my77project. whenever i see it (usually at a glance) i assume that its my77stang and then i wonder why he's askin this question[>:] since he's usually the one that would answer somthin like that
it is a roller cam, and I didn't replace them cause they aren't worn and seem to be jest fine. Thanks for your input. And my gut feeling was that there should be no real reason they HAD to be in order since they were rollers...which it turns out was right. :-)
Sorry my sn offends you. I made it cause it's applicable.
ORIGINAL: greenstreak9205
