ran KOEO/KEOR
Old 12-21-2007, 01:51 PM
nacanitihs
nacanitihs's Avatar
Default ran KOEO/KEOR
ok so w/ the KOEO i got a 67 which is neutral safty switch
w/ the KOER i got a 44 (Thermactor Air Injection system inoperative (Right side).)
and a 94 (Thermactor Air Injection system inoperative (Left side).)
is this just the ACT? or are there two sensors? im confused. can someone plz help me. thanx
nacanitihs is offline
Old 12-21-2007, 02:46 PM
greenstreak9205
greenstreak9205's Avatar
Default RE: ran KOEO/KEOR
thats smog stuff. its prolly not getting any air injected into the heads. do you still have all your smog equiptment on there?
greenstreak9205 is offline
Old 12-21-2007, 02:50 PM
Joel5.0
Joel5.0's Avatar
.... and code 67 was caused by running the KOEO with the transmission in gear, not neutral = operator error. A real code 67 failure doesn't allow a KOER self-test to be initiated.
Joel5.0 is offline
Old 12-21-2007, 05:00 PM
nacanitihs
nacanitihs's Avatar
yep all smog stuff is there.. what should i do?
Old 12-21-2007, 05:08 PM
92cobra
92cobra's Avatar
do you have smog testing in your area?
92cobra is offline
Old 12-21-2007, 05:12 PM
nacanitihs
nacanitihs's Avatar
i dont kno what that is lol. like where would i go?
i prob do since its massachusetts and they are **** about their emissions. well besides cali..
Old 12-21-2007, 08:05 PM
Joel5.0
Joel5.0's Avatar
ORIGINAL: nacanitihs
LOL....you may want to check the banjo/crossover tube that bolts to the back of the cylinder heads..... it should be clogged... + the rear cyl. head ports as well. You could either remove and clean/unclog it (you may need some oxi-ace to "clean the carbon buildup" in the tube), or replace it. The one after the AIRD valve with the check valve hooked up in the diagram below.....
Joel5.0 is offline
Old 12-21-2007, 08:52 PM
nacanitihs
nacanitihs's Avatar
which tube are you talking about? blue or orange? or a diff one? sry if im sped... lol
Old 12-22-2007, 06:35 AM
Joel5.0
Joel5.0's Avatar
Blue.... the one attached to the back of the cylinder heads. The one circled in orange is a hose.
Joel5.0 is offline
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
TCStangerv6
10-11-2015 05:57 PM
Florida Regional Chapter
09-30-2015 08:04 PM
stangin1996gt
09-21-2015 11:01 AM
ctgreddy
09-20-2015 08:35 PM
Quick Reply: ran KOEO/KEOR
