95 GT 5.slow part 2
Old 12-22-2007, 04:57 AM
88GTMustang
88GTMustang's Avatar
Default 95 GT 5.slow part 2
Okay I got all the plugs, wires, cap and rotor changed and the car is still pretty darn slow. Our rental Sentra beat it today. Sad moment I tell ya. What else could be making this thing such a dog? I know they were not super fast stock, but it still idles rough when cold and just doesn't seem to climb very fast in the rpms.
Should I change the coil? I was told they either work, or they don't.
88GTMustang is offline
Old 12-22-2007, 11:27 AM
flyinghigh2k8
flyinghigh2k8's Avatar
Default RE: 95 GT 5.slow part 2
changing the coil wouldn't be a bad idea. Have you tried changing your fuel filter yet??? is it an auto or 5-speed?
flyinghigh2k8 is offline
Old 12-22-2007, 11:59 AM
onebadyfz450
onebadyfz450's Avatar
im in the same boat, i changed all that and still a dog, i bumped up timing and that helped some
onebadyfz450 is offline
Old 12-22-2007, 12:32 PM
Tony71502
Tony71502's Avatar
Def change that fuel filter. You could even change the bladder filter on the pump inside the tank.
Have u cleaned off your MAF and checked for any codes?
Tony71502 is offline
Old 12-22-2007, 12:58 PM
50Stocker
50Stocker's Avatar
I had the same frustration, it was a clogged mass air sensor...I hit it with CRC cleaner and it's great now. Make sure you flog that Sentra for showing up the mustang...
50Stocker is offline
Old 12-22-2007, 01:01 PM
HACKGT350
HACKGT350's Avatar
clean the maf replace the fuel fliter and maybe even the pump check the fuel pressure. bump the timing and do a compression test
HACKGT350 is offline
Old 12-22-2007, 01:38 PM
Alero99
Alero99's Avatar
may just be somthiung inside the engine bro... what things can go wrong internally that could cause cars to run like dick? cracked head? spun bearing **** like that
Alero99 is offline
Old 12-22-2007, 02:07 PM
HACKGT350
HACKGT350's Avatar
oh yeah ever think of checking for a vacuum leak that will make you slow as hell and give you a ****ty idle
Old 12-22-2007, 03:46 PM
bikeboy587
bikeboy587's Avatar
Had the same problem as you and I chased it for 6 weeks.
#1 Clean you MAF Sensor (that was my problem I found after 6 weeks, cleaned it and then the car took off like a bat out of hell. before that my V6 mustang was walking it.) other things I changed and that you can check
#2 Fuel Filter
#3 Fuel pressure (schrader valve on fuel rail)
#4 Fuel pump
#5 coil, cap, rotor, plugs, wires
#6 Clean IAC
#7 Check for clogged cats
#8 Give it a good seafoam, esp the intake
#9 Check timing, set to 10* (stock) until out find the problem, then feel free to advance it to about 12*
#10 Check/scan for any engine codes
#11 Clean the MAF
Did I say clean the MAF? please do that! you may want to erplcae the MAF if the car does not run better after cleaning.
Go to Auto Zone and get a $5 can of MAF cleaner, take it off and hose the **** out of it
bikeboy587 is offline
Old 12-23-2007, 04:46 AM
88GTMustang
It is a 5speed. I cleaned the MAF with rubbing alcohol and it certainly did run a little better, but that was before I changed the plugs and wires. I just can't believe how long it takes to build rpms. Around 3500 rpms it is fading in power.
Quick Reply: 95 GT 5.slow part 2
