Gasoline everywhere
Gasoline everywhere
I have a 94 gt that last winter i did a hci I only drove the car for about a month a i just started taking the motor apart and it smelled like gas inthe lower intake, the exhaust the valve covers and the oil i have no idea wat it could be if you have any ideas please let me know
RE: Gasoline everywhere
smelling gas in the intake is normal because the pcv vents hydrocarbons and crank case vapors into the intake as long as you didn't see puddles of fuel but that'd be hard to see cause fuel is injected straight into the runner and direct into the intake runner on the head......and if the car has ever flooded or hasn't had the oil changed in a while the oil could be saturated with gas..I wouldn't be to concerned but make sure the fuel pressure regulator doesn't have a ruptured diaphram and drawing raw gas through the vaccum line into the intake
Professor Wizard
06-14-2006 03:39 AM
