FUEL INJECTORS??
Old 12-23-2007, 11:26 PM
Esco5.0
Esco5.0's Avatar
Default FUEL INJECTORS??
alright i got a 92 5.0- bbk shorty headers, h-pipe, flow master exhuast, 3:73 gears, cobra clutch, cold air, underdrive pullies, b-camshaft. i wanna put bigger fueal injectors.. can anyone recomend me what size injectors i should put in it or if it would be worth it or not. and any certain ones or anything?? thanks
Esco5.0 is offline
Old 12-23-2007, 11:28 PM
92GreyGT
92GreyGT's Avatar
Default RE: FUEL INJECTORS??
Until you change the heads and intake there isn't much need.
92GreyGT is offline
Old 12-23-2007, 11:56 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
it all depends on what power level you want to obtain in the future..but with bigger injectors you'll need a bigger pump and a adjustable fuel pressure regulator is a good idea.......the stock injectors will support close to 300 hp no problem and right now with your upgrades you still have room for more mods before the injectors duty cycle is maxed out...but if you get a decent set of heads and intake then 24 lbs will be fine if you don't plan to supercharge in the future
mjr46 is offline
Old 12-24-2007, 01:13 AM
89mustangfive0
89mustangfive0's Avatar
im running the 24 pounders in my car with the maf for it with 190 pump
89mustangfive0 is offline
Old 12-24-2007, 01:54 AM
gspfunk
gspfunk's Avatar
What they said...You may want to consider 24's if you go stroker and/or better heads/cam, but you're fine until then. Definitely upgrade your fuel pump when you do the injectors (or before)
gspfunk is offline
GimpyHSHS
19
12-19-2023 01:12 PM
4cylinderplus2
10-09-2020 07:45 PM
Sixx
10-05-2015 07:36 PM
svfetter
10-05-2015 11:39 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: FUEL INJECTORS??
