difference in a 5.0 corba and a 5.0 gt
Old 03-17-2005, 12:10 AM
grabbem88
grabbem88's Avatar
Default RE: difference in a 5.0 corba and a 5.0 gt
stock gt cam with 1.7's on top...24's larger t-body,mass air..,and a gay *** computer that's on the weak side,cause of all the tranny breakage.
grabbem88 is offline
Old 03-17-2005, 01:12 AM
Dan89lx
Dan89lx's Avatar
i knew it was a stock cam, i think they have a 65mm tb and a 70mm maf
Dan89lx is offline
Old 03-17-2005, 02:53 AM
94Cbra
94Cbra's Avatar
Actually the 5.0 Cobra DOES have a specific camshaft, the specs are below along with the other Cobra perks.
Cast iron GT40 heads
Cast aluminum Cobra intake manifold
Crane 1.7 rocker arms
24lb fuel injectors
Cobra specific ECU (computer)
"Cobra" stamped valve covers with build sticker and signature
Engine oil cooler
Front mounted power steering fluid cooler
Lightened flywheel
Phosphate coated transmission gears
Overdriven waterpump pulley
Cobra specific camshaft
Cam specs: Duration: 227°/Intake & 270°/Exhaust
Lift: .485/.485 Intake/Exhaust
Lobe separation: 118.5°
This is just a little extra stuff specific to the 5.0 Cobra as well. The interior and exterior differences arent listed because I figured they were obviouse enough.
Suspension/Brakes
13" Front brakes
11.65" rear brakes
"Cobra" embossed front calipers
Cobra specific brake booster
Cobra specific rear sway bar
Cobra specific shocks/struts/springs
K-member that is slightly stiffer than the GT's
No strut tower brace
94Cbra is offline
Old 03-17-2005, 09:36 PM
zancho93
zancho93's Avatar
ok thanks for all the info but im still a lil bit confused is there really a BIG difference in horsepower, and and which one would be better to upgrade, i was thinking of buying one in the years of 90-93
zancho93 is offline
Old 03-18-2005, 01:35 AM
Dan89lx
Dan89lx's Avatar
nice post man, i didnt realize cobra were upgraded that much as opposed to the gt. I think the 94-95 5.0 cobra's are rated at like 240hp but I have also heard that they are underrated too. They would have to be underrated with the intake,rockers,cam,heads and all that good stuff.
Dan89lx is offline
Old 03-18-2005, 02:10 AM
Quik
Quik's Avatar
93 thru 95 cobras make 235 or so but that same combo made 270 hp. so take it as a cobra makes 270 hp cause with all those mods no way is it only going to make 10hp more then a 92 5.0
Quik is offline
Old 03-18-2005, 03:02 AM
Aliate X
I ♥ Acer
Aliate X's Avatar
ORIGINAL: 94Cbra
24lb fuel injectors
Engine oil cooler
Lightened flywheel
Suspension/Brakes
13" Front brakes
11.65" rear brakes
Awesome post man. I didnt know they were THAT different. Man cobras are really classic.
Aliate X is offline
Old 03-18-2005, 05:47 AM
tyybo
tyybo's Avatar
the cobra is only 235hp?? i find that really hard to believe, the regular gt is rated at like 225 isnt it?
tyybo is offline
Old 03-18-2005, 03:50 PM
Aliate X
I ♥ Acer
Aliate X's Avatar
ORIGINAL: tyybo
Something how its rated wrong, but everyone says its 270-280hp. 235hp my ***, with 1.7 rockers, diff heads and a specific cam? Yeah right. Way more than 235.
Aliate X is offline
Granatelli Sales
03-25-2016 08:01 PM
Granatelli Sales
12-27-2015 06:28 PM
Meystang
09-25-2015 04:05 PM
JT76
09-20-2015 11:32 AM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: difference in a 5.0 corba and a 5.0 gt
