losin my mind
losin my mind
i have a 95 5.0 cobra with 92000 miles on it. i trailered it from ohio to nc. i've been here for 6 months spent every free penny i had and still nothin. also it is a 5 speed. sometimes it acts fine when cold othertimes its not. the rpm's in nuetral and under load are erratic. push the gas and the rpm's go up but keep droppin. i put new plugs,coil, wires ,cap ,rotor button, o2 sensors, battery, fuel filter, and it's still the same. also it is backfiring under load bad with a bad fuel odor. i did run it out of gas in ohio, and when i changed the fuel filter gas on the tank side was rusty colored. im down to timing and fuel injectors unless anybody can think of anything else
[IMG]local://upfiles/87115/4F402C367B97480B84C9E1259D4A3CEB.jpg[/IMG]
[IMG]local://upfiles/87115/59F3A0CB0F4B45FB97C58F8B98C5D1DB.jpg[/IMG]
[IMG]local://upfiles/87115/1CEF897C1CCE463A95D01F91D37E3A22.jpg[/IMG]
RE: losin my mind
ORIGINAL: ampman_27
are you pulling any codes, if not it sounds like the computer.
RE: losin my mind
You said you ran it out of fuel once. Have you checked your fuel pump. My buddy ran his out once and the pump went to sh*t because supposedly the fuel going through the pump lubricates and cools the pump. Soooo no fuel phuked it up i guess. Just an idea.
RE: losin my mind
ORIGINAL: nccobra5.0
Id do the MAF and drop the tank and pull pump, if it needs flushed, dump in some fresh gas and alchohol, run it around holding the tank and dump it some place safe.
RE: losin my mind
Just a silly thing I thought I'd add...
Make sure you run 91 or higher octane, the Cobra has a specific tune that requires it.
EDIT: doh I just saw that you fixed it [:@]nevermind, but what I said is still true.
