1988 mustang engine help.
My 1988 mustang gt's temperature gauge doesen't work and the car is running rich can i get some assistance because none of the ford dealership or othe places cant tell me nothing.
oh yea and there is black smoke coming out of the tail pipe that smells like gas.
RE: 1988 mustang engine help.
so why can't the ford dealership help???? or did you not take it into them and just called them on the phone and expected a free diagnostic over the phone??...first you need to run a koeo/koer test...if that yields nothing you need to check fuel pressure and make sure you don't have a ruptured fuel pressure diaphram and ypu need to get the cars temp gauge working or at least know whay temp the car is at to make sure the car is switching to closed loop operation
ORIGINAL: burtonGT
The for dealership says their computers doesent go back that far the said it was they oxygen sensors and we got the replace and noting changed
http://myshifter.com/joel50/EECTEST.html
With the temp gauge not working, I would say either the wire is off of the sensor on the intake or the sensor itself is bad. Either way, the computer is going to always think the car is running cool, so it is going to be dumping more gas to the motor in an attempt to warm it up. Thereby creating the rich condition.
ORIGINAL: pearce9906
ORIGINAL: mjr46
the temperature gauge in the car will have 0 effect on open vs closed loop operation of the efi system.......now on the other hand if the ect sensor on top of the coolant pipe connection were bad...it will affect closed loop operation..this is the two wire ect and not the 1 wire on the left front of the intake..........and dumping more gas into the motor in an attempt to warm it up???[sm=WTFsgign.gif]....the thermostat is the only device that'll help warm the car up...what will happen if the ect gives a false low reading the car will stay inopen loop fuel contol operation where all fuel calculation is based off a preprogrammed / determined ratio stored in the ecm......where as closed loop operation the a/f is calculated via live inputs sent to the ecm from various sensors such as o/2, mass air, ect, act ...ect ect........you do have one thing correct if ect is bad car will run rich resulting in poor fuel economy
[sm=icon_rofl.gif][sm=icon_rofl.gif][sm=icon_rofl.gif]
KEM Motorworks
08-14-2015 10:13 PM
