front struts is making a hole in my hood.
RE: front struts is making a hole in my hood.
If you put them on you should have read the installation instructions.
Since there are several of you guys with this complaint I think this may be the case.
Here are the instructions- http://www.bbkperformance.com/instal...IPPins_038.pdf
The BBK plates come with shimsto lower the strutif you have clearance issues.
(IE)Struts hitting hood.
You install theshims on the top of the strut before installing it into the bushing of the CC plate. It will push the strut rod deeper so it wont hit the hood.
Youcanadd a washer or two on top of the strut to get more clearance.
Also, you should check the urethane bushings of the CC plate. If the lower bushing is bad the strut will ride higher.
ORIGINAL: cheetha94607
thanks for the info thinking about changing to mms. does anyone have some pictures of mms camber plates installed
And heres where it hit my hood (circles)
inyadreems
08-21-2015 09:10 AM
