What Backspace for Weld Draglites?
I have a 90 notch and am looking to get Weld draglites for it. What backspacing is most commonly used for 15x8 rear and a 15x3.5 up front? I searched and came up with nothing. Have seen different backspacings and I want something is tucked in close to the lip on the quarter panel and fenders and not sticking out at all. Also no rubbing. Hope someone has an answer. Thanks all.
RE: What Backspace for Weld Draglites?
measure the backspacing on your stock wheels and go with that dimension is the best advice I can offer you. I did this for mine and it worked OK but the wider wheel does push the tire out some toward the fender lip but not enough to get all excited about it.
Yeah I was gonna say you can probably fit a 10-inch rim in the rear if you cut it close enough. There is a tool you can get that lets you accurately measure the backspacing you need. The only way to know for sure is to measure. Also keep in mind the tire will stick out a little further than the rim so allow for that when you measure.
09-17-2015 07:57 PM
cardsrus1
19
09-15-2015 08:37 AM
