$$$ Cost of Gear change?
Hey guys, have a A+ condition 88GT 122,000 stick, near future upgrade is a h pipe, BBk headers, and probably Flowmaster exhaust system.
Next idea is gears, currently have 2.73 I think and want to go either 3.55 or 3.73. My question is, what is a normal install with all the necessary bearings etc. going to run me at the local speed shop or garage. Also, what should I make sure they include in the install. Thanks in advance! [sm=icon_rock.gif]
RE: $$$ Cost of Gear change?
I paid 180 for my gears. Shop changed them for 150. Did the same thing as you.. 2.73 to 3.73 ... WOW!!!!! Highly recomend it.. Don;t forget the speedo gear too... You get dizzy watching the miles pile up on the odometer. Oh yeah.. and your mph is a little off.
ORIGINAL: kfellers
How much for the speedo change, and do they do that at the speed shop as well?
Also, will the speedo be pretty accurate after the speedo gear change?
I would budget $500 for the whole thing done right by a good shop. Gears alone will run around $190 or so, good rear end rebuild kit with all the bearings is another $100 and the traction lock rebuild kit is around $50 too and I would definitely have it rebuilt while they are in there. Speedo gear is less than $10 and takes only minutes to install.
musnicki
09-23-2015 07:11 AM
