Trick Flow Twisted Wedge Heads
RE: Trick Flow Twisted Wedge Heads
It seems low because usually it is, most people on 302s dont see over 300whp with the TFS top end kit. With the stock cam you may see around 280whp with a tune, all depends on the car and tune.
Here is how to get power out of this setup.
Trickflow TRACK HEAT INTAKE
Trickflow Heads
Trickflow Stage 1 Camshaft
70mm MAF Calibrated for 24lb Injectors
70mm Throttle Body
Headers
24lb injectors
190lph fuel pump
16* Timing
Replace those old Oxygen Sensors and your set.
Trickflow Heads
70mm Throttle Body
Headers
24lb injectors
190lph fuel pump
16* Timing
Thanks for the help. I have an 87 which is Speed Density not MAF. I may be buying an 88 GT with a blown engine. I can just transfer the computer and the MAF and harness off the 88.
However will this setup work with a Speed Density car?
ORIGINAL: 87Stallion
I am pushing around 250 HP now, so your saying the whole kit only boost HP up to 275. THats alot of cash for 25 HP. No offense but that doesn't make sense to me.
So basically they are a waste of money for the small gain in HP?? I'm ona limited budget so I want the biggest bang for my buck? Am I better off getting GT-40 heads and having them re-worked?
