Torque Specs for 1.6 Pedestal Rockers
12-30-2007, 02:48 AM
I put my engine back together when I did the head gaskets and got the specks for the stock rockers and tighted them up to about 18-25 lbs. I started driving and after about 10 miles the enging started making a noise and i can only think the rockers are too tight. Are the 1.6 pedestal rockers the same torque specs?
12-30-2007, 08:33 AM
RE: Torque Specs for 1.6 Pedestal Rockers
Torque is the same. Did you make sure you dont need shims? Check to make sure one didnt back off.
12-30-2007, 09:03 AM
if theyre too tight , the engine will run like crap cause the valves arent closing all the way. if theyre too loose youll hear a ticking noise.
baddog671
07-26-2016 01:20 PM
Sixer4Life
10-12-2015 04:26 AM
guitarman376
09-30-2015 05:54 PM
wraith777
09-28-2015 10:49 AM
Sixer4Life
09-28-2015 07:05 AM
16,
50,
making,
mustang,
noise,
pedestal,
rocker,
rockers,
sequence,
sopec,
spec,
specs,
tight,
torch,
torque
