must i adjust timing with nos
#21
RE: must i adjust timing with nos
at least a window switch man....Msd digital window switch ($99)...i forgot to mention i have a wot switch and blow down tube too...did you back the timing?
A fuel pressure safety cut off switch is real important too...in case you fuel pump takes a dump it will kill the nitrous when the fuel pressure drops...thus saving your engine!
the vehicle i had the kit on was a 93 lightning...same concept....my car is running 14.2's right now and should be in the 13.8-13.9 range coming here next week...i wanna 12 on the stock block!!
get those safety parts in man and have some fun!
#22
ORIGINAL: roostracing
#23
The new 4.6 kit that is out, mixes fuel with the nitrous and monitors the conditions digitally, all in
one box !
It learns your TPS curve as well, so it kicks in smooth and abrupt, what a rush ! !
Yes it work on your 5.0 JUST FINE
one box !
