i thought it was 1 degree per 50shot, so if you have 100shot take it off 2degrees, if you have 200 shot take it off 4 degress. Dont quote me on this though, i may be wrong.
for every 50 hp shot it is 1-2 degrees from factory base timing setting..so if you run a 150 shot it is reccommended that after 150 shot like with a 175 lets say you should go 1 step colder on the plugs and even at 150 I'd rather be safe than sorry so I'd do 1 step colder on the plug and pull 4 to 6 degrees timing from base.....it's better to be safe than sorry cause when your pounding the motor with NOS you most likely will never hear the detonation even though it is present and before you know it..it'll of hammered the main bearings and or burned a piston
