what gears should i run in my 89 convert?
i have an 89 5.0 convertible that I want to supercharge eventually. I plan on running between 8-10 PSI. what gears should i run? 3.73, 3.9o, or 4.10? what other mods will i need to make a 12 second daily driver/import killer?
RE: what gears should i run in my 89 convert?
3.55 or 3.73 with the super charger. Nothing higher than 3.73. Anything higher and you will have no traction whatso ever. you will blow the tires off constantly. (not literally, i mean lose traction)
to big straight I'll go against most on the gear....with a s/c a 3.27 is the best or even 3.55....I run 3.73's in my fox with 15 spi the problem you have will those 3.90, and up is over driving the S/C what I mean is you'll over rev it right now mine spins around 46,000 rpm, yes under the 50k max but I have seen 50k rpm or charger and they don't live long..and with 3.27 you don't blow the tires up and asum midrange power easier on parts etc
Calizic
08-28-2015 01:46 PM
Figure8allday
08-22-2015 11:11 AM
