Need some advice
Need some advice
ok guys just need some advice. i think this spring i am going to tear the stang down and rebuild it. i think i have a piston ring going out because it burns oil and smokes. i have no clue how many miles are on it because it had a replaced speedo when i got it and it's an ex-patrol car. so i guess my question is where should i look for the best deals on rebuild kits? i don't really want to go to a 306 unless i have to just so i can save some costs at the machine shop. also what would be a good (reasonably priced) H/C/I combo? i know trickflow is good but there's gotta be something that will produce close to the same results for less money. any suggestions/ info would be greatly appreciated!
RE: Need some advice
you can piece together your own kit but the savings will be minimal and power will be greater..which is a better trade off in my opinion......Afr or canfield heads.........rpm II intake or holley systemaxII and for a cam comp xe series or good ots cams and get a dyno tune and all other supporting mods
Omgitsa88Stang
10-05-2015 07:33 AM
