3ag alternator - which one??
RE: 3ag alternator - which one??
https://mustangforums.com/m_3064555/tm.htm
looks like that thread has some information to it, i just skimmed through it though.
ORIGINAL: 92cobra
if you buy a 75-80amp from say autozone for the 87-93foxes you dont need to do anything. i just picked one up and am installing it today. If you grab a 94-95 130amp from autozone you will have to shave your bracket and rewire it. If you search you will find the write up for it on how to install it. Why exactly are you wanting to upgrade over the 75/80amp stock alt?
=P the stock alt is crap i agree buddy, after i install this one here in a few hrs im going to order the summit one if this solves my issue. I just need her up and running and dont want to wait for summits processing and shipping time.
I want to upgrade to a better alternator because when I start the car, it dies. Have to gas it for a bit then drive around before it will idle on its own. Changed battery, so I know it's not it. Like I said, supposedly there are underdrive pulleys and I know it causes problems.
ORIGINAL: 87gt5o
Actually I'm not sure...because it idles kind of high, and then just yesterday it started dying when I turned the car on. So I don't know....could be a vacuum leak but I've looked all over the engine to find vacuum connections and there aren't any hoses. I don't know.....but the voltage on the dash gauge reads pretty low. Just above the red marks at the bottom. About halfway between "empty" and halfway.
I had to get an overdrive pulley after I installed my 3G 200 amp alternator to cure my charging issues, I did the 4 guage power and ground cables on the car and did everything possible, the overdrive pulley cured my problem with charging.
ELEKTRO-FIDE Moderator
Location: In Geo-synchronous orbit over redass' bathroom,
what do you guys think about this one from summit?
http://store.summitracing.com/partde...126+4294925143
sorry bout long link[:@]
