bullet wheels 315 tire!!!!!
RE: bullet wheels 315 tire!!!!!
I have 295X50X15's on the rear on 9" wire wheels,I put 20-25lbs in my air shocks, it does not raise the car, it just makes it firmer, and then they don't touch. I'm going to roll the fenders lightly this spring, and then they won't rub.
Someday I'll get the pic's to work right!
<center>
<img src="http://i154.photobucket.com/albums/s...P7100019-1.jpg" alt="Photobucket - Video and Image Hosting"><br><br>
<img src="http://i154.photobucket.com/albums/s...g/P1010042.jpg" alt="Photobucket - Video and Image Hosting"><br><br>
<img src="http://i154.photobucket.com/albums/s...g/P7100015.jpg" alt="Photobucket - Video and Image Hosting"><br><br>
</center>
Pat
<center>
</center>
Pat
Yea the first two are on 10.5 inch wheels and its what you should get with your car dependiing on how you do your swap. If you use a sn rear end it will stick out a little on each side.You can do a search and I am sure you will find some info on that subject.
I test fit 20 x 10's with 285/30 from my cousins g35on my car. and it fits like reallly flush with the fender. i have to massage the outer fenders a little bit more to get them to fit or i could step down a tire size. AND i still have the quads and an SN95 rear end
ya im planing on useing the ranger axels and i will post pics and a specs on the swap so next time people will knoe if it is possable to do a 315 tire wit a 10.5 rims on a fox . thanks for all ur help!!!!
09-08-2015 11:50 AM
