valvetrain / cam help
RE: valvetrain / cam help
do i need to convert the gt40p's or can i just stay pedistal? and save myself the extra $200 in parts.
im not looking for any high hp race car. im lookin for a 300rwhp DD that i take to the strip now and again.
stock push rod length is 6.250 but depending on the manufactorer..I've seen ford racing list stock as 6.272 and buy the shim kit to be safe..you may use some you may not..I did a valve job so I needed them
how come i cant find that? http://store.summitracing.com/egnsea...splayPrice%7C0
haha thanx. summits category links suck. im still stuck on the springs tho..
will these that telsonman showed me work w/ that cam?
http://store.summitracing.com/partde...p;autoview=sku
what size springs will fit? and what:
Installed Height (in) . Seat Pressure at Installed Height (lbs) . Open Height (in)
Open Pressure (lbs)
will be necessary? sry im a newb to springs..
Open Pressure (lbs)
Pushrods are the last item you should buy after checking what the setup requires. You need to measure what length will provide the best valve train geometry/narrow contact pattern on the valves stem using a pair of adjustable pushrods. For the springs, you could also drop Thumper of Orange Park an email asking for the drop-in valve spring sets he has for the GT40p's. Just a thought.
It's not mandatory to convert your heads to studs to run roller rockers. I run pedistal mounted roller rockers on my P heads. Crane makes a conversion kit to allow the use of roller rockers on a pedistal type head, with no machining needed. I did have to return my Scorpion rockers and exchange them for Crane Energizers, because the Scorpions would hit each other using the pedistal conversion. I wouldn't run these much past 6500rpm (mine are on a 351W in a 4X4 truck), but I'vehad zeroissues with the conversion in 2 years, running a 270H cam.
ok i have the rockers, cam, lifters and pushrods down. what i need to kno is more about the springs.
Installed Height (in). Seat Pressure at Installed Height (lbs). Open Height (in). Open Pressure (lbs)
will be necessary?
will be necessary?
